Use this procedure to configure the Connectivity Fault Management (CFM) Maintenance Association (MA). An MA represents a logical grouping of monitored entities within its domain. It can therefore represent a set of Maintenance Association Endpoints (MEPs), each configured with the same Maintenance Association ID (MAID) and MD Level, established to verify the integrity of a single service instance.
    enable
    configure terminal
  2. Create the CFM MA:
    cfm maintenance-association WORD<0–22> WORD<0–22> [index <1–2147483647>]
  3. Display the CFM MA configuration:
    show cfm maintenance-association
  4. Use the following command, if you want to delete the CFM MA:
    no cfm maintenance-association WORD<0–22> WORD<0–22>
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# cfm maintenance-association md1 ma1 index 98
Switch:1(config)# show cfm maintenance-association
                         Maintenance Association Status
Domain Name            Assn Name              Domain Idx  Assn Idx
md1                    ma1                    1           98
 Total number of Maintenance Association entries: 1.
                         Maintenance Association config
md1                    ma1
 Total number of MA entries: 1.
The following table defines parameters for the cfm maintenance-association command.
Variable
Value
Creates the CFM MA. The first parameter, specifies the MD name. The second parameter, specifies the MA short name.
Specifies a maintenance association entry index.
